hi there - just trying progdvb to see if it can be used as my xbmc pvr app but after installation it won't start, some screen flashes and the progdvb icon appears on the tray but disappears again.... was searching for a log of some kind but cant see nada...
restarted the pc etc but to no avail...
(also tried to install it on a virtualbox virtual winXP and it behaves exactly the same - this is on another physical pc running linux as host and with no tv card)
cheers
michel
