I am using the shareware version of ProgDVB. I tried to watch a channel in HD, and it said I had to choose an H.264/AVC in the settings options. I went through the options and chose one in the drop-down menu. When I clicked "OK", I got an error message with this list of code:
at (* )
at ..( )
at ProgDvbNet.AudioVideoSettingsForm.(Object , EventArgs )
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100)
ProgDvbNet
Assembly Version: 6.2.1.0
Win32 Version: 6.02.01
EngineApiWrapper
Assembly Version: 1.2.2.0
Win32 Version:
msvcm80
Assembly Version: 8.0.50727.762
Win32 Version: 8.00.50727.762
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.762_none_10b2f55f9bffb8f8/msvcm80.dll
System
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.0.8.0
Win32 Version: 1.0.8.0
IPDev.Skins
Assembly Version: 1.3.5.0
Win32 Version: 1.3.5.0
ProgDvbNet.EPG
Assembly Version: 1.0.3.0
Win32 Version: 1.0.3.0
ProgDvbNet.CC
CodeBase: file:///C:/Program%20Files/ProgDVB/ProgDvbNet.CC.DLL
ProgDvbNet.Win
Assembly Version: 1.0.0.0
Win32 Version:
Accessibility
System.Design
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
enabled.
For example:
<configuration>
</configuration>
rather than be handled by this dialog box.Thanks.
