ProgDVB crashing very often
Hello,
ProgDVB crashes very often, here's the report:
   at ()
   at ..()
   at ProgDvbNet.MainForm.(Object , FormClosedEventArgs )
   at System.Windows.Forms.Form.OnFormClosed(FormClosedEventArgs e)
   at IPDev.Skins.SkinForm.OnFormClosed(FormClosedEventArgs e)
   at System.Windows.Forms.Form.RaiseFormClosedOnAppExit()
   at System.Windows.Forms.Application.ExitInternal()
   at System.Windows.Forms.Application.Exit(CancelEventArgs e)
   at System.Windows.Forms.Application.Exit()
   at ..Execute(String cmd)
   at ..(String )
   at ProgDvbNet.MainForm.(Object , EventArgs )
   at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
   at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ToolStrip.WndProc(Message& m)
   at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100)
ProgDvbNet
    Assembly Version: 6.2.3.0
    Win32 Version: 6.02.03
EngineApiWrapper
    Assembly Version: 1.2.3.0
    Win32 Version:
msvcm80
    Assembly Version: 8.0.50727.762
    Win32 Version: 8.00.50727.762
    CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.762_none_10b2f55f9bffb8f8/msvcm80.dll
System
System.Drawing
ProgDvbNet.bc
    Assembly Version: 1.0.8.0
    Win32 Version: 1.0.8.0
IPDev.Skins
    Assembly Version: 1.3.6.0
    Win32 Version: 1.3.6.0
ProgDvbNet.EPG
    Assembly Version: 1.0.4.0
    Win32 Version: 1.0.4.0
ProgDvbNet.CC
    Assembly Version: 1.0.3.0
    Win32 Version: 1.0.3.0
    CodeBase: file:///C:/Program%20Files/ProgDVB/ProgDvbNet.CC.DLL
ProgDvbNet.Win
    Assembly Version: 1.0.0.0
    Win32 Version:
Accessibility
System.Design
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
System.resources
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.resources/2.0.0.0_fr_b77a5c561934e089/System.resources.dll
enabled.
For example:
<configuration>
</configuration>
Cheers,
Ok, there were two modules that I disabled. But I now get this error message:
   at (* , * ,  )
   at ..( ,  diseqItem)
   at ProgDvbNet.MainForm.( ,  )
   at ..(TreeNode ,  )
   at ..(Point ,  )
   at ..(Object , MouseEventArgs )
   at IPDev.Skins.MSTreeView.OnMouseClickEx(MouseEventArgs e)
   at IPDev.Skins.MSTreeView.OnMouseUp(MouseEventArgs e)
   at System.Windows.Forms.TreeView.WmNotify(Message& m)
   at System.Windows.Forms.TreeView.WndProc(Message& m)
   at IPDev.Skins.StyleTreeView.WndProc(Message& m)
mscorlib
ProgDvbNet
EngineApiWrapper
    Win32 Version:
msvcm80
System
System.Drawing
ProgDvbNet.bc
IPDev.Skins
ProgDvbNet.EPG
ProgDvbNet.CC
ProgDvbNet.Win
    Win32 Version:
Accessibility
System.Design
System.Xml
enabled.
For example:
<configuration>
</configuration>
