Do you get any error messages?
Do you have full writing access to the target folder? Any disk quota involved?
yes, always the same vista error message, "progdvb doesn't work anymore/progdvb funktioniert nicht mehr". target folder has full writing access. it also happens when i´m only watching. maybe a buffer problem?
I´m sorry, but i don't understand exactly what you mean with debug key (sorry but my english is not too good).
I tried it again, I recorded for two minutes then it crashed again, maybe this helps:
Produkt
ProgDvbNet
Problem
Funktioniert nicht mehr
Datum
27.12.2008 15:23
Status
Bericht gesendet
Problemsignatur
Problemereignisame: APPCRASH
Anwendungsname: ProgDvbNet.exe
Anwendungsversion: 6.2.3.0
Anwendungszeitstempel: 4953f2d7
Fehlermodulname: ProgDvbEngine.dll
Fehlermodulversion: 0.0.0.0
Fehlermodulzeitstempel: 4953f2cd
Ausnahmecode: c0000005
Ausnahmeoffset: 0001e8ea
Betriebsystemversion: 6.0.6000.2.0.0.768.3
Gebietsschema-ID: 1031
Zusatzinformation 1: 505d
Zusatzinformation 2: 46b544ce2462ef43ee2756dd595678ab
Zusatzinformation 3: 2654
Zusatzinformation 4: fc24ad9dd2c473d0ced574a5b4acd825
Weitere Informationen über das Problem
Bucket-ID: 1072200065
On your desktop or in any folder you like, create another link to (ProgDVB.exe or) ProgDvbNet.exe, with a suitable name like "ProgDVB debug"
Then edit it's properties, like:
...\ProgDvbNET.exe /debug
Store and then use it.
This way you will start ProgDVB in debug mode.
After having done, select the function to debug from the menu.
I created a new link to progDVB but when I want to change the properties (target: C:\Program Files\ProgDVB\ProgDvbNet.exe/debug) an error message opens (windows can't find the file...).
You asre missing a space between the exe name and the argument.
BTW, properties dialog of such a link come with a find target button.
ok, now i got it, the link must be:
"C:\Program Files\ProgDVB\ProgDvbNet.exe" /debug
i started the debug modus, too bad you can't copy the file manager status.
packet errors (after 5 minutes):
dropped: 11002
crc errors: 0
progdvb still crashes after recording 3 minutes.
when i closed progdvb this error message appeared:
Informationen über das Aufrufen von JIT-Debuggen
anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
************** Ausnahmetext **************
System.AccessViolationException: Es wurde versucht, im geschützten Speicher zu lesen oder zu schreiben. Dies ist häufig ein Hinweis darauf, dass anderer Speicher beschädigt ist.
bei ()
bei ..()
bei ProgDvbNet.MainForm.(Object , FormClosedEventArgs )
bei System.Windows.Forms.Form.OnFormClosed(FormClosedEventArgs e)
bei IPDev.Skins.SkinForm.OnFormClosed(FormClosedEventArgs e)
bei System.Windows.Forms.Form.WmClose(Message& m)
bei System.Windows.Forms.Form.WndProc(Message& m)
bei IPDev.Skins.Docking.DockForm.WndProc(Message& m)
bei IPDev.Skins.SkinForm.WndProc(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Geladene Assemblys **************
mscorlib
Assembly-Version: 2.0.0.0.
Win32-Version: 2.0.50727.312 (rtmLHS.050727-3100).
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll.
ProgDvbNet
Assembly-Version: 6.2.3.0.
Win32-Version: 6.02.03.
CodeBase: file:///C:/Program%20Files/ProgDVB/ProgDvbNet.exe.
EngineApiWrapper
Assembly-Version: 1.2.3.0.
Win32-Version: .
CodeBase: file:///C:/Program%20Files/ProgDVB/EngineApiWrapper.DLL.
msvcm80
Assembly-Version: 8.0.50727.762.
Win32-Version: 8.00.50727.762.
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.762_none_10b2f55f9bffb8f8/msvcm80.dll.
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll.
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
ProgDvbNet.bc
Assembly-Version: 1.0.8.0.
Win32-Version: 1.0.8.0.
CodeBase: file:///C:/Program%20Files/ProgDVB/ProgDvbNet.bc.DLL.
IPDev.Skins
Assembly-Version: 1.3.6.0.
Win32-Version: 1.3.6.0.
CodeBase: file:///C:/Program%20Files/ProgDVB/IPDev.Skins.DLL.
ProgDvbNet.EPG
Assembly-Version: 1.0.4.0.
Win32-Version: 1.0.4.0.
CodeBase: file:///C:/Program%20Files/ProgDVB/ProgDvbNet.EPG.DLL.
ProgDvbNet.CC
Assembly-Version: 1.0.3.0.
Win32-Version: 1.0.3.0.
CodeBase: file:///C:/Program%20Files/ProgDVB/ProgDvbNet.CC.DLL.
ProgDvbNet.Win
Assembly-Version: 1.0.0.0.
Win32-Version: .
CodeBase: file:///C:/Program%20Files/ProgDVB/ProgDvbNet.Win.DLL.
ProgDvbNet.resources
Assembly-Version: 0.0.0.0.
Win32-Version: 0.0.0.0.
CodeBase: file:///C:/Program%20Files/ProgDVB/de-DE/ProgDvbNet.resources.DLL.
System.Windows.Forms.resources
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
Accessibility
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll.
System.Design
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll.
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll.
System.resources
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.resources/2.0.0.0_de_b77a5c561934e089/System.resources.dll.
System.Drawing.Design
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing.Design/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll.
mscorlib.resources
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
************** JIT-Debuggen **************
Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der
Konfigurationsdatei der Anwendung oder des Computers
(machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.
Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
Zum Beispiel:
<configuration>
</configuration>
Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten
Ausnahmen an den JIT-Debugger gesendet, der auf dem
Computer registriert ist, und nicht in diesem Dialogfeld behandelt.
