Problem using controls
1 post
New user
New user
Tue Dec 23, 2008 7:54 am
#1 by New user
Hello,
I clicked "Settings > Controls" to look at shortcuts to choose channels using the command line or the keyboard but it doesn't work as expected. For instance, if I hi "1" on my keyboard, this doesn't change the selected channel. Also, if I open MS-DOS and run:
"C:\Programs\ProgDVB\ProgDVBNet.exe 1"
I get a prompt asking for admin privileges instead of changing the channel. Has someone been able to use controls? How do we use them?
Thanks,
  • Sun Dec 28, 2008 12:02 pm
1 post
Sorry. Updated. https://i.hizliresim.com/w1sj3lwn.jpg Okay. For now, I can watch 4K broadcasts without any proble
Fikret Turedi, Tue Aug 25, 2026 9:25 am
Sorry. Updated.
Prog, Tue Aug 25, 2026 9:12 am
Thanks for sample. Please try prerelease of ProgDVB. https://i.hizliresim.com/smxookin.jpg Unfortunately, both l
Fikret Turedi, Tue Aug 25, 2026 8:57 am
  • It is currently Tue Aug 25, 2026 11:35 am
