Problems with Streaming
Hello,
I have the Nexus-s in my Server-PC. I downloaded the newest Version of ProgDVB an install it on my Server and on my Client-PC. I configurate the Server-Settings correctly. The Server and the Client show me the Traffic. The Signal of my Client is full and I can change the Channel with the Clinet.
But my Problem is, I have no video and no sound at the Client side. PowerDVD and ffdshow is installed on Client and Server. I had probe to change the codec-Edits but ist works not.
What can I do?
regards
Cetin
yes, I have traffic on Client.
PS-Format ??
do you opine "Program Stream" ?
I can only selet "program stream" or "transport stream".
I use at moment the Freeware-Version, therefoce I use the unicast-Streaming. Where I can set the "PS" format ?
@Prog
I have installed ProgDVB 5.16.02.
With this version, the sreaming works fine.
do you fix the bug in the newest version, becouse the new version is more stable then older versions??
