Viewing USB accessories with ProgDVB
Hi all
using the professional version, I would like to know if it could be possible viewing 2 USB peripherals installed on my system (I already have a Terratec BDA PCI card for cable, which is perfectly running with ProgDVB)
Those peripherals are a Logitech 4000 webcam and a USB capture card with composite cable linked to a STB.
In the progdvb menu>settings>device list, I found a Logitech QuickCam Pro 4000 TVin and a Logitech QuickCam Pro 4000 in, but when I select either these peripherals, I get the message "No one streamingTV found in this TV. Can't start module".
Same issue with the other USB peripheral, the AVER MEDIA C038 USB capture Card in and TVin.
Both are perfectly working on other applications, ie. the webcam with the logitech software, and the AverMLedia capture card with ATV2000. But I would like to keep Progdvb as my only viewer.
PS before asking this question, I made a search with the keyword USB, without success.
