ProgDVB 6 Pro crashes after a few seconds
Hello,
I´ve a problem. I´ve purchased the pro-version of ProgDVB before a few minutes.
But If I watch a TV- or radio-channel, prodvb crashes after a few seconds.
Here´s the error-message:
Beschreibung:
  Stopped working
Problemsignatur:
  Problemereignisname:	APPCRASH
  Application Name:	ProgDvbNet.exe
  Application Version:	6.2.3.0
  Application Timestamp:	4953f2d7
  Fault Module Name:	empgpdmx.ax
  Fault Module Version:	1.2.14811.0
  Fault Module Timestamp:	48fc36b7
  Exception Code:	c0000005
  Exception Offset:	000401bf
  Betriebsystemversion:	6.0.6001.2.1.0.256.1
  Gebietsschema-ID:	1031
Lesen Sie unsere Datenschutzrichtlinie:
  http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0407
A second error-message:
Beschreibung:
  Stopped working
Problemsignatur:
  Fault Module Name:	ProgDvbEngine.dll
  Fault Module Version:	0.0.0.0
  Fault Module Timestamp:	4942ccf9
  Exception Offset:	00070a40
I use the 64-bit-version of windows vista ultimate. PID-Recorder and Prog Media Server are disabled.
Video-Render is VMR-9, Audio is Default DirectSound Device.
I hope you can help me.
Thanks in advance
Regards from Germany
Markus
(ProgDVB Pro)
Signal-Level is at 100%,
Plugins: No Plugins used
CheckForUpdatesOnStart was disabled :(
Edit: Before a few seconds I´ve tried to change a channel and received following error-message:
System.Runtime.InteropServices.SEHException: External component has thrown an exception.
   at (* , * ,  )
   at ..( ,  diseqItem)
   at ProgDvbNet.MainForm.( ,  )
   at ..(TreeNode ,  )
   at ..(Point ,  )
   at ..(Object , MouseEventArgs )
   at IPDev.Skins.MSTreeView.OnMouseClickEx(MouseEventArgs e)
   at IPDev.Skins.MSTreeView.OnMouseUp(MouseEventArgs e)
   at System.Windows.Forms.TreeView.WmNotify(Message& m)
   at System.Windows.Forms.TreeView.WndProc(Message& m)
   at IPDev.Skins.StyleTreeView.WndProc(Message& m)
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.1434 (REDBITS.050727-1400)
ProgDvbNet
    Assembly Version: 6.2.3.0
    Win32 Version: 6.02.03
    CodeBase: file:///C:/Program%20Files%20(x86)/ProgDVB/ProgDvbNet.exe
EngineApiWrapper
    Assembly Version: 1.2.3.0
    Win32 Version:
    CodeBase: file:///C:/Program%20Files%20(x86)/ProgDVB/EngineApiWrapper.DLL
msvcm80
    Assembly Version: 8.0.50727.1434
    Win32 Version: 8.00.50727.1434
    CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.1434_none_d08b6002442c891f/msvcm80.dll
System
System.Drawing
ProgDvbNet.bc
    Assembly Version: 1.0.8.0
    Win32 Version: 1.0.8.0
    CodeBase: file:///C:/Program%20Files%20(x86)/ProgDVB/ProgDvbNet.bc.DLL
IPDev.Skins
    Assembly Version: 1.3.6.0
    Win32 Version: 1.3.6.0
    CodeBase: file:///C:/Program%20Files%20(x86)/ProgDVB/IPDev.Skins.DLL
ProgDvbNet.EPG
    Assembly Version: 1.0.4.0
    Win32 Version: 1.0.4.0
    CodeBase: file:///C:/Program%20Files%20(x86)/ProgDVB/ProgDvbNet.EPG.DLL
ProgDvbNet.CC
    Assembly Version: 1.0.3.0
    Win32 Version: 1.0.3.0
    CodeBase: file:///C:/Program%20Files%20(x86)/ProgDVB/ProgDvbNet.CC.DLL
System.Xml
ProgDvbNet.Win
    Assembly Version: 1.0.0.0
    Win32 Version:
    CodeBase: file:///C:/Program%20Files%20(x86)/ProgDVB/ProgDvbNet.Win.DLL
Accessibility
System.Design
enabled.
For example:
<configuration>
</configuration>
Markus
(ProgDVB Pro)
BTW, try to remove the file "empgpdmx.ax".
Prog wrote:Do you have subtitles on this channel? Is it depended from channel?
No, it happended on all channels, also radio or something other.
Markus
(ProgDVB Pro)
