Dear experts,
I have some noises when listening to radio channels. I have no similar noises on ProgDVB old versions like 4.85. Any confirmation or solution?
Thank you all in advance
I should add that the noises only appear only on a few seconds after switching to any radio channel (E13). However the noises sometimes come and go. Is there any confirmation?
Dear Prog, thank you very much for your reply. Yes, Same without audio processor. My audio processor is Sonic Focus (Intel Audio Studio).However when I switch it off, the noises will reduce little bit. How can I change the audio codec? Can you please explain.
Thank you again.
Thank you again.
