I have kowrld dvb-s 100
work fine with BDA device
no support 4X1 switch Diseqc (only work First port)
http://img114.imageshack.us/img114/3225/21741223vi0.jpg
and also can enable Kowrld device, but you need DVB-plus which old application for this card by manufacture
if you lost this application kowlrd device will not work
http://img114.imageshack.us/img114/3407/53769436ng1.jpg
but with Kowlrd device approximately with all versions of Prog make crash when start
http://img387.imageshack.us/img387/7754/35142644bi4.jpg
and length lost and need to restart the machine
http://img114.imageshack.us/img114/954/73544798uj0.jpg
except few old version workd Fine ,but also with this I use XP sp 2 .
e.g. with SP3 he make erro message (send/don't send ) and
there is no length lost but you note work slowly when star\close program .
so can may any fix with kowrld device which support switch Diseqc .
regards
