    • Unanswered topics
    • Active topics
Important BUG ! ProgDVB 6.03.01 no video with TT 2300 S
maxmc
maxmc
Sat Oct 04, 2008 9:37 pm
#1 by maxmc
In the newer version 6.03.01 with Technotrend S 2300 (in hardware mode) there is no video but only audio (no problem in the previous version with the same settings.
How can I do ?
Thanks.
Max
  • Wed Jan 07, 2009 6:42 pm
Hardmode?
  • Wed Jan 07, 2009 8:43 pm
maxmc
maxmc
#3 by maxmc
Yes in hardware mode not software mode. Channels are regularly sintonised but no video when I open the program.
  • Wed Jan 07, 2009 8:51 pm
#4 by Prog
What last good ProgDVB version?
  • Wed Jan 07, 2009 8:56 pm
maxmc
maxmc
#5 by maxmc
Just the previous one 6..03
  • Wed Jan 07, 2009 8:58 pm
#6 by Prog
Hm. OK. Thanks. I thy fix that in next version.
  • Wed Jan 07, 2009 9:02 pm
maxmc
maxmc
#7 by maxmc
Ok problem solved in the current 6.01.02 version !
I have now a more technical question. What is in your opinion the best value of the max record speed parameter in the Time shift buffer setup (default is 3000KByte) and there is a connection with the records quality ?
Thank you
  • Sat Jan 10, 2009 6:39 pm
#8 by Prog
6.03.02 or 6.01.02?
No, record quality not depended from parameters. Also all they parameters not used in hardmode.
  • Sat Jan 10, 2009 11:07 pm
maxmc
maxmc
#9 by maxmc
little mistake, the version with NO BUG is 6.03.02. Thank you for the answer.
  • Sun Jan 11, 2009 9:25 am
Re: Падает инсталлятор
Обновил пререлиз. Добавил доп строки в installation.log. Пришлите мне его если снова повиснет.
Prog, Sun Feb 01, 2026 7:18 am
Есть идея. Если при установке выключить регистрацию планировщика, которая включена по умолчанию. Не виснет?
Prog, Sun Feb 01, 2026 6:42 am
Русских буфк в пути нет? Имя аккаунта в винде из простых английских букв, одно слово, соответственно путь к профилю
f2065, Sat Jan 31, 2026 10:04 pm
Re: проблемма со звуком
Стоп. Проблема с aac или только с aac 5.1?
Prog, Sat Jan 31, 2026 5:48 pm
  • It is currently Thu Feb 12, 2026 5:24 am
