hello
my hardware is Kworld DVBs-100
my pc p4-3000mhz
2gb ram
nvidia gf 8600 512mb
i have installed ProgDVB 6.03.01 on vista clean install
i have search the channels it is done well to the end of searching process.
after that when i select any channels (FTA) the program crashed (closed)
i have no plugin installed
also i have red about disable Settings->Options->Audio->Audio processor
nothing changed
i only use ProgDVB4.85.1 is the last most stable one on vista
any one can help me please ?
all versions after 4.85.1 crashed on selecting any channel
i mean in the start thier is no selected channel
just when i click on any channels (FTA) the program crashed (closed)
i dont know what is the problem?
i have selected it but it dosen't work
my hardware has the latest driver
the version 4.85.1 work perfect on windows vista
each time you fix bugs on newer versions the same error comes
i think it is the device module in your prodvb device list in newer versions is not combatable with windows vista
what happens with me:
i start the program without selecting a channel
when i click once on free to air channel without plugin installed
i hear 1 second sound and some times see 1 second picture
then the program crashed( ProDvbNet has stoped working)
then i goto the device maneger
disable the hardware then enableing it again
to make the hardware work properly and start the progdvb 4.85.1
it works fine without any probleme on vista
hello
did you find a solution for my problem?
i any help from u will has a value for others
thaks
thaks
