Hello @all,
one Question,
can i use this Card: Lifeview DVB Trio Cardbus DVB-T+DVB-S+Analog+HDTV+AV-IN with ProgDVB?
hello
I have some problem with this card in ProgDVB. I use progdvb with the BDA digital driver (DVB-T).When I scan channel with it, ProgDVB sniff and find the channel but he don't display the video and audio though the gauge of signal strenght reception is at 100%. I can send a complete graph (with graphedit) of this card if you want.
Thanks in advance for your help.
Krys
Krys
choose one of the filtergraphs there ...proper codecs must be installed on your pc...
btw. these channels in your list are only data channels...without video and Audio Pid´s...
ProgDVB can not do DVB-H, that's for handhelds and similar devices.
And it's NOT free, and it's technically completely different.
That's why it shows up as data channels, no dedicated Audio and Video IDs available.
Look for other signals, marked TV or Radio.
Search the (technical) provider's pages for channels, frequencies, IDs and alike.
Cross check (and perhaps post) channel properties of a main (real DVB-T) station.
Try if you can get EPG resp. 'What's now' and 'What's next' there, or TXT.
If one of those is available, you can start working on the codec stuff...
