    • Unanswered topics
    • Active topics
NEW BUG in version 6.03.03
maxmc
maxmc
Sat Oct 04, 2008 9:37 pm
#1 by maxmc
After an EPG programmed record, the program hangs up and it is necessary to CTRl ALT CANC it.
I have a TT PREMIUM 2300 S
With the previous version this not appened.
Thanks
MAXMC
  • Tue Jan 20, 2009 12:02 pm
Is it hardmode?
  • Tue Jan 20, 2009 12:05 pm
maxmc
maxmc
#3 by maxmc
Yes it is I always use it in hardmode.
THanks
  • Tue Jan 20, 2009 12:06 pm
maxmc
maxmc
#4 by maxmc
The program also freezes sometimes when changing channel during normal vision.
  • Tue Jan 20, 2009 12:42 pm
vanadium
vanadium
Fri Jan 02, 2009 7:55 am
#5 by vanadium
Hi there, Also when switching to internet TV, it stops working. any solution or confirmation?
  • Tue Jan 20, 2009 3:00 pm
#6 by Prog
ProgDVB can frezz for 2-3 seconds when internet TV closing. I am not know why :-(
  • Tue Jan 20, 2009 4:30 pm
maxmc
maxmc
#7 by maxmc
Yes but after recording it freezes always when I can exit from the program, and it also hangs up the TT PREMIUM.
Can we download the previsou version 6.03.02 ?
  • Tue Jan 20, 2009 6:34 pm
#8 by Prog
You can use old link for previuos version.
  • Tue Jan 20, 2009 9:15 pm
maxmc
maxmc
#9 by maxmc
Where is the link ?
  • Wed Jan 21, 2009 8:16 am
#10 by Prog
http://files.update-progdvb.com/ProgDVB6.03.01Std.exe
  • Wed Jan 21, 2009 8:38 am
maxmc
maxmc
#11 by maxmc
First of all I have purchased the professional version (the link you have provided refers to the standard one) and furthermore the last good version is the 6.03.02 and not the 6.03.01.
So the indicated link is wrong !
Thanks
  • Wed Jan 21, 2009 11:48 am
#12 by Prog
http://download.progdvb.com/trial/ProgDVB6.03.02Pro.exe
  • Wed Jan 21, 2009 3:29 pm
Re: Падает инсталлятор
Обновил пререлиз. Добавил доп строки в installation.log. Пришлите мне его если снова повиснет.
Prog, Sun Feb 01, 2026 7:18 am
Есть идея. Если при установке выключить регистрацию планировщика, которая включена по умолчанию. Не виснет?
Prog, Sun Feb 01, 2026 6:42 am
Русских буфк в пути нет? Имя аккаунта в винде из простых английских букв, одно слово, соответственно путь к профилю
f2065, Sat Jan 31, 2026 10:04 pm
Re: проблемма со звуком
Стоп. Проблема с aac или только с aac 5.1?
Prog, Sat Jan 31, 2026 5:48 pm
  • It is currently Thu Feb 12, 2026 5:24 am
