Ini file transponder line ending in 910,S2
1 post
ketje
ketje
Tue Dec 19, 2006 11:47 am
#1 by ketje
When a transponder definition ends with 910,S2 in a .ini file, it appears as an "auto" FEC when selecting to scan that transponder.
When ProgDVB scans the transponder (as "auto"), it finds nothing and it is neccessary to manually set the FEC to 9/10 in order that ProgDVB identifies and lists the channels on the transponder.
Best example of such transpoders are those found on 23.5e.
  • Sat Jan 31, 2009 4:00 pm
1 post
Sorry. Updated. https://i.hizliresim.com/w1sj3lwn.jpg Okay. For now, I can watch 4K broadcasts without any proble
Fikret Turedi, Tue Aug 25, 2026 9:25 am
Sorry. Updated.
Prog, Tue Aug 25, 2026 9:12 am
Thanks for sample. Please try prerelease of ProgDVB. https://i.hizliresim.com/smxookin.jpg Unfortunately, both l
Fikret Turedi, Tue Aug 25, 2026 8:57 am
  • It is currently Tue Aug 25, 2026 11:34 am
