I am new to progDVB, and just purchase a copy of progDVB pro, progDVB Server and the Elecard H264 codec to stream the DVB-T signal to other clients on my network. (I am using VLC as the client application software.)
The problem I am facing is:[b] the progDVB always hangup. [/b]It hangup after I stream the digital TV channels via the progDVB for several hours.
I found that the window reports that the progDVB hangup is due to the "[b].Net Runtime 2.0 Error[/b]". My working environment is XP with SP2 and .Net Framework 2.0. The progDVB pro is 6.04, prog media server is small version. I stream the TV channels using multicast function.
How can I select the "/NoGraph" option? Do you mean the progDVB can be called via the command prompt?
I have already try the /NoGraph option by typing the following in the command prompt:
C:\Programs Files\ProgDvb>ProgDVBNet.exe /Nograph
The same error message displays after the progDVB loading (about 2/3 of the process)......
