Prog DVB and these questions
1 post
backyard
backyard
Mon Feb 16, 2009 5:18 am
#1 by backyard
I have a prog DVB software, some times it records some channels, but other channels were not>> if you use media player or real player to play some video saved files will not work.. if you use power DVB it works.. so why some time the video file works, and other video files not work??
other question
what this soft ware used for??
thank you
  • Mon Feb 16, 2009 5:28 am
1 post
Sorry. Updated. https://i.hizliresim.com/w1sj3lwn.jpg Okay. For now, I can watch 4K broadcasts without any proble
Fikret Turedi, Tue Aug 25, 2026 9:25 am
Sorry. Updated.
Prog, Tue Aug 25, 2026 9:12 am
Thanks for sample. Please try prerelease of ProgDVB. https://i.hizliresim.com/smxookin.jpg Unfortunately, both l
Fikret Turedi, Tue Aug 25, 2026 8:57 am
  • It is currently Tue Aug 25, 2026 11:34 am
