recording two dvb-t channnels?
i want to buy asus Eee PC 1000HE (atom n280 and 1 gb memory)
atom n280 = 1.66GHz and 667MHz FSB
http://www.asus.com/products.aspx?l1=24 ... odelmenu=2
and terratec dvb-t Cinergy DT USB XS Diversity (two dvb-t tuner)
http://www.terratec.net/en/products/Cin ... _1608.html
or
two pieces terratec dvb-t Cinergy T USB XE
http://www.terratec.net/en/products/Cin ... _1672.html
i want to record two dvb-t channels at the same time with progdvb soft.
is it posible? my hardware anough for two channel recording with progdvb?
if yes how?
do i must run two progdvb soft at the same time ?
Prog wrote:It is possible in one ProgDVB Pro. But not all hardware support that.
good.. than i buy progdvb pro.
but you know my hardwares.
progdvb pro support terratec dvb-t Cinergy DT USB XS Diversity and or terratec dvb-t Cinergy T USB XE ?
and does asus Eee PC 1000HE (atom n280) enough for two dvb-t channel recording at the same time with progdvb pro ?
