ProgDVB 6.04.04 Profesional crash when comm. with device
Hi all,
I wanted to test HDTV reception, so I upgraded from basic ver. to ProgDVB 6.04.04 Profesional, but it crashes as soon as communication invokes to device. i.e start of the channel scan.
My device is Winfast USB2 DTV dongle DIB 7700 from Leadtech.
With basic ProgDVB 6.04.04 there are no issues seen and app. works very well.
I reinstalled .NET2.0 fram the scratch, also updated with KB923028-X86.exe, but no success.
Would appreciate any support to be able to make it
log attached:
at (* , * , )
at ..( , diseqItem)
at ProgDvbNet.MainForm.( , )
at ProgDvbNet.MainForm.(Object , EventArgs )
at System.Windows.Forms.Form.OnShown(EventArgs e)
at IPDev.Skins.SkinForm.OnShown(EventArgs e)
at System.Windows.Forms.Form.CallShownEvent()
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
ProgDvbNet
Assembly Version: 6.4.4.0
Win32 Version: 6.04.04
EngineApiWrapper
Assembly Version: 1.2.5.0
Win32 Version:
msvcm80
Assembly Version: 8.0.50727.762
Win32 Version: 8.00.50727.762
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700/msvcm80.dll
System
Win32 Version: 2.0.50727.794 (QFE.050727-7900)
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.0.10.0
Win32 Version: 1.0.19.0
IPDev.Skins
Assembly Version: 1.3.6.0
Win32 Version: 1.3.6.0
ProgDvbNet.EPG
Assembly Version: 1.0.5.0
Win32 Version: 1.0.5.0
ProgDvbNet.CC
Assembly Version: 1.0.4.0
Win32 Version: 1.0.4.0
CodeBase: file:///C:/Program%20Files/ProgDVB/ProgDvbNet.CC.DLL
ProgDvbNet.Win
Assembly Version: 1.0.0.0
Win32 Version:
Accessibility
System.Design
System.Xml
System.Drawing.Design
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
enabled.
For example:
<configuration>
</configuration>
