HD change channel problems
hi, using latest version of progdvb pro, azurewave dvb-s2 ( AD-SP 400 ) with latest drivers also, running vista x64 everything seems ok but if i go from a sd channel like bbc 1 to a HD channel there is never no quality or signal but if i select bbc hd its fine, i am using the latest transponders list and all sky 28.2 channels are shown in the list...disney hd, movies hd etc..
any help would be nice
cheers
nobod had this problem ? it only does it on sky uk every other satellite with hd is ok,, also another problem i didnt mention in the advert say a program stops for commercial break the picture stops while its showing breakes but once the program returns it shows ok, so during commercial adverts i get a still picture,,
cheers in advance guys
can anybody reconmmend a good card so i can watch hd tv please also with DISECQ 1.2 ,as i think im wasting my time with the card im currently using, i have tried every driver, differant versions of windows and i have also checked signals with my meter to make sure hd signals are actually presant, i have worked out maybe a update from microsoft is the problem but only hazard a guess as i installed a fresh version of vista 32 bit, signals ok for about couple of hours was able to flick from one hd to another, left over night and it installed updates and now im back to square one, no signal on hd :(
i guess nobody has ever had this problem be fore then only me
cheers
