Recently bought one of these satellite receivers. However, I have this problem with it and can't get it to work properly. I do think my signal is good enough, but i only see small sqares of the whole pic, just like it does with "normal" satellite receivers when the signal is bad.
But when i tried with another receiver which is connected directly to the tv everything works fine, but cant get it to work it with my computer, so the antenna should be aimed like it should .
This it what it looks like:
Hope you all understood what i'm trying to say
