select channels for EPG
hello, i use progdvb on my LCD TV and i used EPG interface just for main DVB-T channels that i watch (9)..
i needed to re-install progdvb and now i can't figure out how to select channels i want to appear in EPG (rsp. how to remove the ones that i do not want there...)
i have channel list filtered to just TV and i additionally deleted all channels i do not watch, but in EPG i have all channels found including radio stations and so on..
what i want is to have only these 9 channels to appear in EPG. i used to have it like that, but i forgot the procedure :(
it makes the sense to do that through "delete channel from base", but this command removes all channels, not only selected.
i have the latest free version..
thanks for help..
