I can't allow that live link to that place.
First of all, it's in arabic (or similar), so I can't find out, if it's legal or not.
Then, it requires a registration, to read there.
So people over here can't even see that picture.
Of course ProgDVB supports DVB-S.
That's what it started with, many years ago, and most users are on digital satellite.
But your tuner (resp. it's driver) also has to be supported.
What kind of driver does it have, old style WDM or modern BDA?
If it's WDM,you are in need for a suitable device file for it (if exists).
For BDA driven devices, you may have to install and set up the original application, to create all the registry settings the BDA device requires to work. After having dome this, you should normally find a suitable BDA device with a name, that points to your hardware. Activate that and start setting up ProgDVB. Check device options, then do LNB / DiSEqC settings.
Perhaps create a screen shot of the device list in ProgDVB.
