64-bit version of ProgDVB 6.06.2 for Windows XP64/Vista64
Hi all,
I've got a Hauppauge HVR-1200 with Vista Media Center Edition SP1 64 bits, and when I install 64-bit version of ProgDVB 6.06.2 for Windows XP64/Vista64, I can´t mark the option for analog device, so I can watch DVB-T channels but I can't do the same with analog channels. As in Media Center you must research all channels for switching between analog and digital, it would be very usefull for me your support for both platforms, but I don't know if this feature isn´t included in this release of Prog DVB or if it doesn´t work on my system for missconfiguration.
Thank you so much for your help in advance.
I've tried 32 bit version 4.92.4 and 6.06.2, but both of them hang in te starting screen. If you know any other solution to this issue it would be great.
Thanks any way.
