help with kworld remote
hello
my card is kworld dvb-s 100
remote work perfect with the application that come with
the tuner(DVBS Plus and there is new vesion of this 'HyperMedia 2.5')
when you run remote file, you can choose in one of the two apllcation you want .
type of remote for this tuner come attached with the card and string with ir lens to connect.
BTW technical support inform me :
"1) Please update the Microsoft .NET.Framwork to latest version.
In our understanding, you must update some Microsoft Hotfix files by using ProDVB Version 5 above.
Please contact the ProDVB tech support to get more detail information for using ProDVB.."
can I use remote in Prog DVB??
thanks.
in the CD that come with the tuner,
installing the driver which contain driver and remote control Utility ,
I found it work as keyborad
I found (up,down.left ,right and enter)
I can switch between channels in Progdvb as with this as keyboard.
but after Kowrld update the Driver ,application and remote Utility ,
remote Utility no longer work as keyboard.
but I can run the old one with , no problem .
sos13 wrote:in the CD that come with the tuner,
I can not adjust remote control. Write please the program version kworld software from which you work
