Query about te vii b420
Sat2009
Sat2009
Sat Apr 04, 2009 12:22 pm
#1 by Sat2009
hi everybody ,
is this card (te vii b420) supported on progdvb ?
which one i can choose from the list ( use standard)
  • Tue Jun 09, 2009 12:50 am
Yes, supported. You can select BDA driver.
  • Tue Jun 09, 2009 6:20 am
Вы мне логи крашей присылали?
  • It is currently Sat Jun 27, 2026 10:00 pm
