ne channellist after changing dvb-t usb stick
1 post
Medeno
Medeno
Sat Jul 04, 2009 3:12 pm
#1 by Medeno
Hi,
I installed the actuall version with hauppauge dvb-t usb stick (wintv-nova-t-stick model-353). Worked fine.
Now I bought the hauppauge wintv-hvr 930c. WinTV Software works. But after starting Progdvb no channel was found in the channellist.
Device is connected. When searching for channels the search is ended directly with empty window.
I uninstalled progdvb and installed new, but same result.
Seems there is a hidden ini.
Rgds Medeno
  • Sat Jul 04, 2009 3:21 pm
1 post
  • It is currently Tue Aug 25, 2026 8:38 am
