The client A is receiving the unicast streaming of the server but not the client B, even if the client A is down.
Both progdvb clients are in version 6.10.2 and installed the same way on similar machines with same OS version.
On client B there is no Progdvb client visible in the device list !
I would like to be sure that the Prog Media server trial version is working on all clients before buying it.
#3Hi Prog,Prog wrote:Please use 6.11
You are right, it works on all clients with version 6.11, thanx a lot.
But if the server progdvb pro 6.10.2 is dispatching HD content, the clients in standard version 6.11 cannot read it, i receive following message: "H.264/AVC and DVB-S2 supported only in Pro version of ProgDVB".
Do i really have to pay a pro version for every client(childrens) for seeing some channels in a good quality on their PCs ?
