hey hey,
i've just updated to the latest progDVB and have chosen the 'Australia - All Channels' as well as done a blind search but can only find 1 channel (Channel9 - both the standard and hi-def versions).
I can't seem to find any other channels!?
I have tried all sorts of different settings but to no avail. The reception is fine, I had no problem with previous versions...
Any help appreciated!!
Yep just had the same problem....
However I set my BDA device to advanced in the Device List, this crashed ProgDVB, upon restart I did another scan & all my channels showed up correctly.
Before that I could only get the first transponder in the seach to register channels, oddly when I did a manual scan on a latter transponder, it would come up with the same channels as the first transponder...
I ended up with 30+ channels all from the same transponder.
My issue now is the EPG doesn't seem to work, but it did before the crash !
Cheers
Cheers
No I have what I believe now is full functionality.....
I have disable the advanced BDA since I was getting a message that it was unable to start on each program startup.
I have two other questions though...
1. When I change channels I sometimes get a loud audio spike. It there any muting when a channel is changed?
2. How do I get the onscreen display to come backup other than reselecting that particular channel again?
Cheers
Cheers
