.ts recording problems in newer versions of ProgDVB
I have used exclusively ProgDVB 6.05 for a long time now almost solely for recording. I decided then to update it to the newest version (6.11.5) and recorded a program which included DVB-subtitles. I was surprised to notice that the subtitles were missing from the .ts (as well as teletext stream and others), and ran some tests using two working versions of ProgDVB and ProjectX.
Screenshots of the results below:
Version 6.05
Contents of the .ts container recorded with 6.05 and viewed with ProjectX
Version 6.11.5
Contents of the .ts container recorded with 6.11.5 and viewed with ProjectX
So I have now the two versions installed and their settings are similar in all aspects. My OS is Windows 7 RTM x64 and I use Artec T14BR on BDA-driver (tried Generic and Microsoft compliant, same results).
So what could cause such a behavior and is there a solution to it (other than sticking to version 6.05)?
Is this because of my setup or changes in ProgDVB itself?
