I have a problem with ProgDVB6:
After a while of watching TV the sound and image suddenly stop for some seconds (or slow down). This leads to mixing up sound and image, so that they don't fit to each other anymore.
Everytime this happens the number next to "Cache overflow" increases, and sound and image stay mixed up until I restart the channel.
I have already set the cache to 9000KB, but it doesn't fix the problem.
If I disable the video buffer, the problem is solved, but i need the timeshift feature.
ProgDVB 5.16.2 works perfectly, but i'd more like to use the newer version of ProgDVB..
Can anyone help me?
Thanks in advance,
Julian
