Hello ,
can someone tell me why i have bad quality video on Channel using ProgDVB?
i have 1 GB Nvidia Graphic Card
i'am using now progDVB 6.05.02 Standart Edition + Compro VideoMate S300
my question is that relation with codec or with Full paid ProgDVB version
Thanks
does progDVB pro Version include those codec
cause i wanna buy Pro Version specially for Quality cause i'am really getting headeache when i move from my pc to receiver
or could you please link me the CyberLink + EVR to download ?
Thanks
Thanks
ok but which option should i edit ?SiLencer wrote:EVR means = Enhanced Video Renderer
Settings => Option => Video =>
Video Renderer
MPEG-2
H.264/AVC
WMV
MPEG4
MPEG43
MPEG4s
Thanks Prog
Remember when you want to use the EVR Video mode with windows XP you need to install the NETframework 3.5/SP1 packages.
For me the standard Overlay Video Renderer (OSD not Supported) gives the best result.
Unfortunately this Video mode is still broken in the last versions of ProgDVB.
Re: 6.20.02: Overlay/Video Renderer problem?
ok can someone help me ?
i will pay him if he would like to help to get good quality as i have last Nvidia GEforce 1 GB + Good PC
Thanks & much appreciated
And ´CyberLink´ is Part of the cyberlink powerdvd Player ...just install the Trial ...and you have the codec in your system...and you can use it in progdvb ...even...when the trial period of the player is over...
Hi Thanks ,
i did installed CyberLink PowerDVD 9 but when i go settings option video i dont see that coded on the combobox for list choice ?
how i can enable it ?
Thanks
Thanks
#15
Hello bro ,
after i installed your version & when i go to render i dont find the cyberlink codec look here on this pic what i have
first pic is when i click on render option
second pic is when i click on MPEG-2 option
as you can see i dont get the codec on render option which change the quality ...
Thanks
Thanks
