After instalation of 6.21, it was impossible to setup a tv card, the transponder lists wil not show - the diseqc setup wrongly apears in a terrestrial tv card.
No more tests, returned to old versions.
Re: Basic problems in 6.21.x series
#3I had the same experience - using Twinhan DTV-card.marec wrote:After instalation of 6.21, it was impossible to setup a tv card, the transponder lists wil not show - the diseqc setup wrongly apears in a terrestrial tv card.
Working very good with version 6.20.03 - so I went back to that until problem is solved.
/ rogermoor
#4I have the same problem here with my TechnoTrend C1501 DVB-C card.?marec wrote:After instalation of 6.21, it was impossible to setup a tv card, the transponder lists wil not show - the diseqc setup wrongly apears in a terrestrial tv card.
Impossible to configure card with correct provider/transport lists.
Using provider menu settings shows wrong options dialog.
Impossible to set up DVB-C card correctly, can not use/test this version 6.21.
