i would really thank for your effor Prog , but as i love Progdvb i want it to be the best & stable
by the way i code on .NET so i understand in real what is ..
here you a list of bug ,
1-sometimes when you move to some channel it raise exception alone..
(i dont know the origine of that but it has a lot of on Jazeera & Sky channel) so better when you move to a new channel remove the messagebox raising the exception
2-Record Part is really buggy
2-a: when you change resolution on Record setting for height & width
instead wen you change the textbox value of height you made mistake with the textbox of width value
2-b:when i made get default back on record tab
now i cant record ? how simply the pic speak it self , the size still 0 mb..
3-Satellite Channel
3-a) a really problem on this when searching a new channel
sometimes some channel dispear while searching not all of them got scanned
4-i got back to the version 6.05.02 cause in real the new version gui is bad i talk about each channel icon in the right ..
Question : how i can make my own Skin ?
Thanks
