Using now 4.88 - which works greats but it has no DVB-S2 support. So, I decided to buy and dl-ed PRO versions - 4.92.4 and 6.21.1.Description:
Faulting application name: ProgDVB.exe, version: 4.0.0.0, time stamp: 0x46975f9d
Faulting module name: bda.device, version: 0.0.0.0, time stamp: 0x4624f0f7
Exception code: 0xc0000005
Fault offset: 0x000028fa
Faulting process id: 0x12a0
Faulting application start time: 0x01ca4e9fe75cfc7a
Faulting application path: C:\Program Files (x86)\Grafika\ProgDVB\ProgDVB.exe
Faulting module path: C:\Program Files (x86)\Grafika\ProgDVB\Modules\bda.device
Report Id: 3e07fa3b-ba93-11de-b5ff-005056c00008
6.21.1 - sound problems with directsound, tryed every possible codec /filter/. The main look (channellist) is weird for me.
4.92.4 - can´t tune in any DVB-S2 transp (DVB-S yes). Got actual ini (works in ProgDVB v.6). Also it reports EVR is not supported.
1 - Is there any way I can make old 4.85.3 works? Would be best choice for me.
2 - Why can´t I tune DVB-S2 in 4.92.4 (4.88.1 too)? Also why is EVR not working for me?
Thx!
HW - Q6600, 8GB RAM, EP35-DS3R, Audigy 2, SkyStar HD2, Win7/64 Ultimate, SSHD2 driver - 1.3 (1.1.1.502)
