ok, sorry, but pretty standard config
Win XP SP3, ProgDVB regulary updated, so now 6.22
the thing is, its not even about numpad, but if i set the number keys to any key (i tried the F as seen below), it just doesnt switch the channel after pressing... you can also see that i have only 9 channels, so i used to use numpad 1-9 for direct switching to channel with that number..
it does't respond in any window/mode
learn works fine
no doublets
