Win7 x64 + ProgDVB 6.21 - 6.23 x86 + IRDETO CI not working
tubeme
tubeme
Tue May 19, 2009 8:21 pm
#1 by tubeme
ProgDVB 6.20.04 x86 + Win7 x64
decodes the programs OK
ProgDVB 6.21 - 6.23 does NOT decode the programs with
IRDETO CI.
  • Thu Oct 29, 2009 9:20 pm
What DVB device you have?
  • Thu Oct 29, 2009 9:25 pm
tubeme
tubeme
#3 by tubeme
TT 3650 CI
  • Fri Oct 30, 2009 4:44 pm
#4 by Prog
Check settings->Device options. Must selected technotrend.
ps: Only x32 ProgDVB support CI for technotrend.
  • Fri Oct 30, 2009 7:03 pm
#5 by Prog
Try update this file
http://test.progdvb.com/BDA.7Z
  • Fri Oct 30, 2009 8:12 pm
tubeme
tubeme
#6 by tubeme
This file solved the problem.
Thanks Prog for your efforts.
Now th 6.23 decodes the programs Perfect.
  • Mon Nov 02, 2009 12:08 am
  • It is currently Tue Aug 25, 2026 7:06 am
