ProgDVB & Windows 7
Hi,
I try to use ProgDVB with MSI Digi Vox mini II.
Channels are found, sound is available, but the video doesn't work.
It states "Probably one of necessary codecs is not chosen or not installed on your computer".
Basically it's a helpful advice.
Unfortunately, I'm an absolute newby. I have no idea, what to to do, install or configure.
Any help is highly appreciated.
Thanks in advance
Dirk
Prog wrote:Try start ProgDVB with /Debug key at first. You can select codecs in Settings->Options...
Done thatand recieved the message from ProgDBVengine "Create filter error (Video Decoder)".
What does that mean?
Again, I have absolutely now experience. For me it should just start and run properly.
Thanks
Dirk
Prog wrote:Than mean you not select good video codec in settings->Options->Video
What codec should I select for audio and video?
I have no additional codec installed, just those which are available per default.
Thanks
Dirk
Thanks
Dirk
i Would suggest on Audio if you have RealtekHD is Good
& cyberlink coded for video or ulead video coded
