i installed progdvb and when i open it i got this message :
progdvb a rencontré un probleme est doit se fermer , i try many time but the same message what i must to do please help me ?
Try to remove the file "empgpdmx.ax" from the subfolder "Filters".
if that dont work save your record files + plugins..
and uninstall Full progdvb... & after it finish go on progdvb folder you will still have some 5 files or so delete them also & do reboot and install fresh one again.
i had the samething done those steps & problem solved.
