Record Video Problem
Hello ,
i face a problem when recording is that when i click record
i see the record icon started at that time but in fact when the record finished i see that the record video start after ~6 second from the time i started recording and end after ~10 second from the time i stopped recording.
which affect & cause problem for my recorded video :(
Thank to fix this prog.
Yes, it is possible. ProgDVB not mpeg2 editor not can record from same frame. Delay can depended from timeshift mode, record format, ...
Prog wrote:Yes, it is possible. ProgDVB not mpeg2 editor not can record from same frame. Delay can depended from timeshift mode, record format, ...
alright i see
any plan on futur this problem to be fixed ?
cause for me is a lot of
