Thanks guys for that great software i used ist serveral jears ....
but now i have a little problem.
we changed our sat config
now we have 2x Quadro LNB (Kathrein UAS 584) at
one 9/8 Multiswitch (Kathrein EXR 2908)
to the problem i cant switch it i Have
Astra 19,2° on Pos. A
Hotbird 13° on Pos. B
with normal FTA Reciver all working fine
i tryed Every combination for an switch you have in the config
Technisat Skystar 2 HD CI USB API set to technisat
Driver and ProgDVB is latest version
Multiswitch is Self Powered
the internal conifg of the Multiswitch is
Diseqc ON (22Khz and Toneburst set to OFF for faster chanceover
Diseqc Comands Are
Pos.A
Low Band Vert. E2 10 38 F0
Low Band Horz. E2 10 38 F2
High Band Vert. E2 10 38 F1
High Band Horz. E2 10 38 F3
Pos.B
Low Band Vert. E2 10 38 F4
Low Band Horz. E2 10 38 F6
High Band Vert. E2 10 38 F5
High Band Horz. E2 10 38 F7
Diseqe Off (22khz for High/Low and Tone Burst for Pos.A / Pos.B
please help me
best regards
Axel
Technisat Skystar 2 HD CI USB Probs with Multiswitch
