Issue with channels and spectral inversion
Hi,
I've tried ProgDVB 5 and ProgDVB 6 (the lastest versions) and stuck with the same problem. Some channels are only found then spectral inversion device option is "On" and some channels then spectral inversion is "Auto". It means that I can't switch from one channel group to another without changing device options. Any clue how to solve this issue? Maybe it's possible to adjust spectral inversion parameter under each channel? Sadly I haven't found such.
I use: TechnoTrend Premium C-2300 (DVB-C) card under Windows XP. Original TechnoTrend software finds all channels without problem, but no luck with ProgDVB.
Another issue I face: Prog Media Server (bundled with ProgDVB 5) works, but version bundled with ProgDVB 6 doesn't send any packets - I'm checking Statistics tab under Prog Media Server and it doesn't show any traffic. The older version works well and I'm able to see not only traffic in the Statistics part, but also succesfully connect with Prog Media Client. Any ideas how to debug the problem? (I've allready checked the networking/firewall part - it's not in there)
I'd also like to get some hint how to get ProgDVB controlled remotely. I use DVB-C mostly for video recording, so looking for some remote webGUI to be able to control recording scheduler. Anypne uses ProgDVB for that?
br
You are partly correct, spectral inversion may change from one transponder to the other. So theoretically this should be a parameter of the transponder list entries, like DVB-S2 is.
