Re: automatic gain control
Is it just me who first always hits 'new topic' instead of 'post reply' ? !
I wanted to add, yes, I also find the automatic gain control setting is not retained from one run of ProgDVB to the next.
I assume it is only known to work with some specific setups?
Lee
Hauppauge WinTV-NOVA-HD-S2 (PCI). Fixed dishes on Astra1, Astra2, Hotbird and Hispasat. DiSEqC 1.0. Windows 7 Home Premium 32 bit. I also have a WinTV-NOVA-S-USB2.
Prog wrote:Same if enable AGC over main form or OSD?
Hello Prog,
I'm sorry but I don't really understand what you mean.
Basically, I haven't yet found a way to keep the automatic gain control turned on, between one run of ProgDVB and the next.
Lee
