Recording problem please help
jennyseibert
jennyseibert
Sat Jul 03, 2010 7:15 pm
#1 by jennyseibert
Hello, i try to record in wmv format but there is no file created...mpg format and ts are working. i have got windows 7 64 bit. please help me. thank you
  • Sat Jul 03, 2010 7:19 pm
Re: Recording problem please help
Do you have any error messages? What channel type?
  • Sat Jul 03, 2010 8:07 pm
jennyseibert
jennyseibert
#3 by jennyseibert
no there is no error. it says recording and time is counting but size is 0. i tried many different channels.
  • Sat Jul 03, 2010 8:14 pm
Akad
Akad
Tue Apr 29, 2008 6:42 pm
#4 by Akad
jennyseibert wrote:Hello, i try to record in wmv format but there is no file created...mpg format and ts are working. i have got windows 7 64 bit. please help me. thank you
Please run progdvb with /debug and show the log file (progdvb.log).
  • Sat Jul 03, 2010 9:15 pm
jennyseibert
jennyseibert
#5 by jennyseibert
How can I do that?
  • Mon Jul 05, 2010 6:33 am
Akad
Akad
#6 by Akad
jennyseibert wrote:How can I do that?
If you use to launch progdvb shortcut - click properties. In line object add to text ".....ProgDVB\ProgDvbNet.exe" /debug. Then run progdvb.
  • Mon Jul 05, 2010 3:10 pm
jennyseibert
jennyseibert
#7 by jennyseibert
i did what you told me but it gets a error message. what could i do else to solve wmv problem?
  • Tue Jul 06, 2010 9:01 am
jennyseibert
jennyseibert
#8 by jennyseibert
can anyone tell me what codec i have to use/install to record in wmv format?i am now using wmvideo decoder dmo
  • Fri Jul 09, 2010 12:17 pm
Akad
Akad
#9 by Akad
jennyseibert wrote:can anyone tell me what codec i have to use/install to record in wmv format?
Any WM codecs: 8/9/11.
  • Fri Jul 09, 2010 11:21 pm
  • It is currently Tue Aug 25, 2026 4:58 am
