Channel search 6.49
werwohl
werwohl
Sat Oct 30, 2010 7:30 pm
Channel search 6.49
#1 by werwohl
By performing a Channel search some channels are found, but in the summary the found channels are not visible, so no found channel is stored.
Cu,
Robert
ProgDVB 6.49 Stanard - WIN XP
  • Sat Oct 30, 2010 7:47 pm
Re: Channel search 6.49
Channel list->Deleted?
  • Sun Oct 31, 2010 8:43 am
werwohl
werwohl
#3 by werwohl
Prog wrote:Channel list->Deleted?
Channel List - Properties and other selection in the window at the bottom side of the dialogbox solved the problem.
I was confused of the usage of the Channel List.
Thanks,
Robert
  • Sun Oct 31, 2010 8:06 pm
  • It is currently Tue Aug 25, 2026 3:59 am
