DiSEqC 1.1 on Tevii No Function!
shikip
shikip
Thu Feb 11, 2010 12:11 pm
#1 by shikip
Hi, still Progdvb version 6.05 I have no DiSEqC 1.1(for 8 satellites) function on my TeVii S460 DVB-S2 PCI Driver 20100421! I allrady post my problem but I did`t find a solution! Must I do something special in options or whaiting for a new soft! Thanks!
  • Sun Oct 31, 2010 11:13 am
Re: DiSEqC 1.1 on Tevii No Function!
At first please install last version of ProgDVB. No any problems with Diseq 1.1 with this device on ProgDVB level.
  • Sun Oct 31, 2010 12:24 pm
shikip
shikip
#3 by shikip
Thank you for the answer, I did install the last version (6.49) and and made it fast with every version before but without success! I can`t scan nothing but 1(the first) Satellite position! That`s on Win7 64 and WinXP x86! Thanks
  • Sun Oct 31, 2010 7:46 pm
#4 by Prog
try change settings->device options
  • Mon Nov 01, 2010 6:55 am
shikip
shikip
#5 by shikip
Prog wrote:try change settings->device options
Hi you meen to change the Tevii driver with Microsoft DVA compliant or Generic BDA drivers? Thanks
  • Tue Nov 02, 2010 12:25 am
#6 by Prog
NO! I mean delay and "repeats".
  • Tue Nov 02, 2010 8:06 am
shikip
shikip
#7 by shikip
Hi What should I change delay=? and repead=? This function was`t in version 6.05 but the DiSEqC 1.1 work perfect! whay did`t they work in a new versions (for me) is the kernel different? Thanks
  • Wed Nov 03, 2010 12:05 am
  • It is currently Tue Aug 25, 2026 5:16 am
