    • Unanswered topics
    • Active topics
64-bit version: No sound on Vista Ultimate 64-bit
michael46
michael46
Sat Jul 18, 2009 8:58 pm
#1 by michael46
Since version 6.24 I don't get sound on Vista 64-bit. I tried all possible audio codecs but no success.
Video is fine. :cry:
  • Wed Nov 03, 2010 6:22 pm
Re: 64-bit version: No sound on Vista Ultimate 64-bit
Do you select cocec in ProgDVB settings? What type of audio stream?
  • Wed Nov 03, 2010 6:49 pm
michael46
michael46
#3 by michael46
I select codecs in ProgDVB (e.g. "Default") and I also tried unselecting "use audio processor" in Options => no success.
  • Wed Nov 03, 2010 7:36 pm
michael46
michael46
#4 by michael46
The problem is still there with version 6.50. I can see the audio signal in the equalizer but I don't here any sound.
  • Sun Dec 19, 2010 11:12 am
#5 by Prog
Try start with /Debug key. Any error messages? Do you use spdif?
  • Sun Dec 19, 2010 1:42 pm
michael46
michael46
#6 by michael46
I don't use Spdif. By using the /Debug switch ProgDVB does not produce any error message.
  • Mon Dec 20, 2010 11:19 am
michael46
michael46
#7 by michael46
Isn't there anybody having a similar problem or who can give a hint?
  • Thu Jan 13, 2011 2:16 pm
#8 by Prog
Try disable Audio processort (settings -> Options->Audio)
  • Thu Jan 13, 2011 2:37 pm
Re: IPTV channel list issues
leading . characters causes issues and are stripped in the channel list leading * characters works ok
noremorse57, Thu Sep 11, 2025 2:52 pm
Re: ProgTV WinUI3
Это поверх старой версии ставилось? Проверю
Prog, Thu Sep 11, 2025 4:43 am
Re: ProgTV WinUI3
У вас какой-то глюк с таймшифтом в последней версии. Смотрите, сколько у меня мегабайт выставлено. И это ставил не я. Эт
kostan, Thu Sep 11, 2025 2:26 am
Re: ProgTV 3.8.3 - Trail Peri…
The Name, Email, and Key fields are blank. There are numbers in the HID field. Do you want them? I have installed 3.8.
MG317, Wed Sep 10, 2025 3:11 pm
  • It is currently Mon Sep 15, 2025 1:26 pm
