Unable to get this version to run (also ProgDVB6.49.3std). Have no video or audio, signal indicator L=solid Q=nothing but have strap line display correct current programme, Task Manager reports ProgDVB running and CPU activity is similar to ProgDVB running OK. Have tried reloading hauppauge drivers, uninstal ProgDVB, cold boot and re-instal with no result. All previous versions upto 6.49 have "worked out of the box", version 6.49.0std re-loaded and is running fine. All tests Astra 28.2E on CNBC.
Any ideas?
TV Card: Hauppauge WinTV Nova HD S2
Drivers: WinTV v7 CD 2.2
OS: Windows XP Pro
Re: ProgDVB6.49.4std
#2Check Settings->Device options. More stable if "User tuner request ..." enabled. But more slow.
#3Checked that the box is ticked OK. Have tried a re-scan on 28.2E, scans 10729V OK, then cycles through 16 transponders adding no channels but sig L=solid Q=nothing as changing transponder but returns on lockon to lcirca level I would expect, from transponder 17 to completion L=solid Q=nothing and no channels added. On completion have the channels on 10729V sound and video OK all other channels reported lost. Have uninstalled cold boot and re-installed drivers and ProgDVB6.49.4 same result, instal 6.49std either as cold boot instal or "overlayed" all works fine on the channel list provided.
