Exception when starting 6.49.05 HD
I have a TechniSat SkyStar S2 (Art: 4103/3734) which works with the SD version of progdvb.
I've just installed the Pro version into a new folder and activated it but it only allows me to set up the DiSEqC (a 4x1 switch) but when I try to access any channels SD or HD I get an exception.
This is the first part of the internal debug report:
System.OutOfMemoryException: Out of memory.
at System.Drawing.Graphics.CheckErrorStatus(Int32 status)
at System.Drawing.Graphics.DrawImage(Image image, Rectangle destRect, Int32 srcX, Int32 srcY, Int32 srcWidth, Int32 srcHeight, GraphicsUnit srcUnit, ImageAttributes imageAttrs, DrawImageAbort callback, IntPtr callbackData)
at System.Drawing.Graphics.DrawImage(Image image, Rectangle destRect, Int32 srcX, Int32 srcY, Int32 srcWidth, Int32 srcHeight, GraphicsUnit srcUnit, ImageAttributes imageAttr, DrawImageAbort callback)
at System.Drawing.Graphics.DrawImage(Image image, Rectangle destRect, Int32 srcX, Int32 srcY, Int32 srcWidth, Int32 srcHeight, GraphicsUnit srcUnit, ImageAttributes imageAttr)
at IPDev.Skins.SkinLabel.DrawLabelImage(Graphics g)
at IPDev.Skins.OSDForm.(Control , Graphics , Control , Point )
at IPDev.Skins.OSDForm.DrawToBitmap(Bitmap bitmap)
at IPDev.Skins.OSDForm.DrawFormToLastBitmap()
at IPDev.Skins.OSDForm.RaiseDrawOSD()
at ProgDvbNet.OSDChannelCaptionForm.(Object , EventArgs )
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
Progdvb recognizes it as: (WDM) Skystar S2 TV PCI on both the SD and HD version.
I should say that the S2 works on SD and HD FTA channels using the s/w that came with the product so it is not a h/w problem.
BTW the Settings > Device options doesn't allow any further option (I read another thread about changing that). I guess I could get around that by editing the .ini file when it is not running.
Any help welcome.
Re: Exception when starting 6.49.05 HD
This is a temporary problem. Skineditor seriously reworked. So far, use the earlier version.
there is no need to manually edit the file. u can uncheck some panel in options-osd and determine fail one
See last version with fix this problem-just now :)
