Re: Transponder scan of "Hot Bird 6,8,9" causes an exception
I deleted all the old transponder lists out of the transponder folder, downloaded the new lists from "http://www.fastsatfinder.com" and un-zipped them into the transponder folder. Deleted the contents of the channel folder and then did a channel list/channel scan/13' Hot Bird, at which point I get the error. I have always done it this way in the past without problem.
